@Mario1577 I got the same messages like you expect the text below that said [ INFO] [1493416155.381228171]: Connection established . How did you able to solve the problem. Here are the steps i followed in case it helps to site the problem.
- git clone from https://github.com/clearpathrobotics/vrpn_client_ros
- export vrpn_root = path to where it cloned
- sudo apt-get install ros-kinetic-vrpn-client-ros
- run catkin_make
- roslaunch vrpn_client_ros sample.launch server:=233.255.42.99
Do you have the same ip in roslaunch vrpn_client_ros sample.launch and motive optitrack?
Yes I use the same IP which is 233.255.42.99 for both the launch file [quote=“kjkidusj, post:21, topic:2956”]
[/quote] and Motive too
@Mario1577 Can you guide me through the steps you followed?
I do not use virtual machine, I am using two Pc, maybe this guide can help you https://github.com/EmaroLab/docs/wiki/Motion-Capture-Instructions-(Optitrack-Motive)
In the guide use virtual machine.
Hope this can help you.
I am using a windows pc and ubuntu pc
The windows pc i have motive software and ubuntu pc I have ROS,
I connect both computers via LAN with router.
In ubuntu pc I installed vrpn_client_ros.
finally, I run roslaunch vrpn_client_ros sample.launch server:=ip
the ip that i am running in sample.launch is the same that has motive and windows pc.
Could you send optitrack data to ros? @kjkidusj
So is this IP address is multicast default address (239.255.42.99) or is it the ip address of the PC? My PC is connected to internet through cable.
No I couldn’t I am still trying to figure out it!!!
Is there anyone who is using Virtual Machine to run ROS and able to stream data from Optitrack successfully? I would appreciate your help on this one please.
