I am trying to use visual odometry (using an Otus tracker: Otus Tracker) with the PX4 running LPE.
I am not managing to fuse the data as the mavros/local_position topics are not being published.
I am currently using the topics, which are properly publishing, mavros/vision_pose/pose_cov mavros/vision_speed/speed_twist
and have set the vision_speed/listen_twist to true. Also, in the QGroundControl I have modified the parameters LPE_FUSION to 4 (so it fuses with vision position) and ATT_EXT_HDG_M to 1.
After all these, the following topics /mavros/local_position/odom /mavros/local_position/pose /mavros/local_position/velocity
have nothing published on them.
Pixhawk 2.1 with firmware v1.8.0 is being used.
I wold appreciate any kind of help or feedback if anyone has encountered the same issue or knows how to solve it.
@Jaeyoung-Lim Seeing that I can’t manage to do it with vision, I am implementing it with mocap atm. However, even though I have modified ATT_EXT_HDG_M to Mocap in the QGroundControl, mavros is not subscribing to mavros/mocap/pose…
Okay @Jaeyoung-Lim, managed to do it with mocap. Looks like that, somehow, I put mocap to the blacklist in px4_pluginlists.yaml.
Thank you very much for your help and sorry for the double reply.
