What does it take for a parameter to become used?
I know I've defined it correctly (in parameters.c
under my sensor driver subdir and it is visible under build/build_name/parameters.xml
with correct annotations), I've also referenced the parameter in ROMFS/px4fmu_common/init.d/rc.sensors
(as the parameter itself is a simple on/off switch for a sensor driver), but it is not visible in QGroundControl and param show
in nsh does not mark it as used.
If I reference it in ROMFS/px4fmu_common/init.d/rcS
(the reason why I tried that is that the only distance sensor-related parameter visible in QGroundControl is for LL40LS and it is referenced in rcS
), my parameter DOES become used, however the annotations in QGC are missing (i.e. it seems that I can change the value, but I don't get nice drop-down).
Thank you in advance!
Karolis
