Hello everybody,
I changed my Ubuntu version on my computer and while i'm trying the make px4fmu-v2_default, an error occurred.
This is what Ubuntu says :
I already tried the "sudo apt-get install ninja-build" Then "make distclean" and "make px4fmu-v2_default" but it didn't change anything.
What can I do ?
drone@drone-Precision-T1600:~/src/Firmware$ make px4fmu-v2_default
-- PX4 VERSION: v1.8.0-1788-ge9fb17c51a
-- CONFIG: nuttx_px4fmu-v2_default
-- Build Type: MinSizeRel
CMake Deprecation Warning at /usr/share/cmake-3.10/Modules/CMakeForceCompiler.cmake:69 (message):
The CMAKE_FORCE_C_COMPILER macro is deprecated. Instead just set
CMAKE_C_COMPILER and allow CMake to identify the compiler.
cmake/toolchains/Toolchain-arm-none-eabi.cmake:30 (cmake_force_c_compiler)
/usr/share/cmake-3.10/Modules/CMakeDetermineSystem.cmake:94 (include)
CMakeLists.txt:176 (project)
CMake Deprecation Warning at /usr/share/cmake-3.10/Modules/CMakeForceCompiler.cmake:83 (message):
The CMAKE_FORCE_CXX_COMPILER macro is deprecated. Instead just set
CMAKE_CXX_COMPILER and allow CMake to identify the compiler.
cmake/toolchains/Toolchain-arm-none-eabi.cmake:36 (cmake_force_cxx_compiler)
build/nuttx_px4fmu-v2_default/CMakeFiles/3.10.2/CMakeSystem.cmake:6 (include)
-- The ASM compiler identification is GNU
-- Found assembler: /usr/bin/arm-none-eabi-gcc
-- Found PythonInterp: /usr/bin/python (found version "2.7.15")
-- Found PY_jinja2: /usr/local/lib/python2.7/dist-packages/jinja2
-- C compiler: arm-none-eabi-gcc (15:6.3.1+svn253039-1build1) 6.3.1 20170620
-- C++ compiler: arm-none-eabi-g++ (15:6.3.1+svn253039-1build1) 6.3.1 20170620
-- PX4 ECL: Very lightweight Estimation & Control Library v0.9.0-608-gacde4eb
-- Building and including px4io-v2
-- NuttX: px4fmu-v2 nsh cortex-m4
-- ROMFS: px4fmu_common
-- Configuring done
-- Generating done
-- Build files have been written to: /home/drone/src/Firmware/build/nuttx_px4fmu-v2_default
ninja: Entering directory `/home/drone/src/Firmware/build/nuttx_px4fmu-v2_default'
[0/647] git submodule platforms/nuttx/NuttX/nuttx
[1/647] git submodule src/lib/ecl
[2/647] git submodule src/drivers/gps/devices
[7/647] Building px4io-v2
-- CONFIG: nuttx_px4io-v2_default
build/nuttx_px4io-v2_default/CMakeFiles/3.10.2/CMakeSystem.cmake:6 (include)
-- NuttX: px4io-v2 nsh cortex-m3
-- Configuring done
-- Generating done
-- Build files have been written to: /home/drone/src/Firmware/build/nuttx_px4io-v2_default
ninja: Entering directory `/home/drone/src/Firmware/build/nuttx_px4io-v2_default'
[0/208] git submodule platforms/nuttx/NuttX/nuttx
[2/208] git submodule platforms/nuttx/NuttX/apps
[208/208] Creating /home/drone/src/Fir...px4io-v2default/px4io-v2_default.px4
[12/647] git submodule mavlink/include/mavlink/v2.0
[14/647] git submodule platforms/nuttx/NuttX/apps
[645/647] Linking CXX executable nuttx_px4fmu-v2_default.elf
FAILED: nuttx_px4fmu-v2_default.elf
: && /usr/bin/arm-none-eabi-g++ -fno-common -ffunction-sections -fdata-sections -mcpu=cortex-m4 -mthumb -mfpu=fpv4-sp-d16 -mfloat-abi=hard -fno-common -ffunction-sections -fdata-sections -g -fno-exceptions -fno-rtti -std=gnu++11 -fno-threadsafe-statics -DCONFIG_WCHAR_BUILTIN -D__CUSTOM_FILE_IO__ -fcheck-new -Wall -Wextra -Werror -Warray-bounds -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wmissing-declarations -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-implicit-fallthrough -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -Wunused-but-set-variable -Wformat=1 -Wno-overloaded-virtual -Wreorder -Wno-format-truncation -fvisibility=hidden -include visibility.h -fno-strict-aliasing -fomit-frame-pointer -fno-math-errno -funsafe-math-optimizations -ffunction-sections -fdata-sections -fno-strength-reduce -fno-builtin-printf -Os -DNDEBUG -mcpu=cortex-m4 -mthumb -mfpu=fpv4-sp-d16 -mfloat-abi=hard -nodefaultlibs -nostdlib -Wl,--warn-common,--gc-sections platforms/nuttx/CMakeFiles/nuttx_px4fmu-v2_default.elf.dir/__/__/src/platforms/empty.c.obj -o nuttx_px4fmu-v2_default.elf -L/home/drone/src/Firmware/build/nuttx_px4fmu-v2_default/external/Install/lib -nodefaultlibs -nostdlib -fno-exceptions -fno-rtti -Wl,--script=/home/drone/src/Firmware/build/nuttx_px4fmu-v2_default/NuttX/nuttx/configs/px4fmu-v2/scripts/ld.script -Wl,-Map=nuttx_px4fmu-v2_default.map -Wl,--warn-common -Wl,--gc-sections -Wl,--start-group NuttX/apps/libapps.a NuttX/nuttx/arch/arm/src/libarch.a NuttX/nuttx/binfmt/libbinfmt.a NuttX/nuttx/libc/libc.a NuttX/nuttx/configs/libconfigs.a NuttX/nuttx/libxx/libcxx.a NuttX/nuttx/drivers/libdrivers.a NuttX/nuttx/fs/libfs.a NuttX/nuttx/mm/libmm.a NuttX/nuttx/sched/libsched.a -Wl,--end-group -lm src/modules/uORB/libmodules__uORB.a src/drivers/barometer/ms5611/libdrivers__ms5611.a src/drivers/differential_pressure/ms4525/libdrivers__ms4525_airspeed.a src/drivers/distance_sensor/ll40ls/libdrivers__ll40ls.a src/drivers/distance_sensor/sf0x/libdrivers__sf0x.a src/drivers/gps/libdrivers__gps.a src/drivers/imu/l3gd20/libdrivers__l3gd20.a src/drivers/imu/lsm303d/libdrivers__lsm303d.a src/drivers/imu/mpu6000/libdrivers__mpu6000.a src/drivers/imu/mpu9250/libdrivers__mpu9250.a src/drivers/magnetometer/hmc5883/libdrivers__hmc5883.a src/drivers/px4flow/libdrivers__px4flow.a src/drivers/px4fmu/libdrivers__px4fmu.a src/drivers/px4io/libdrivers__px4io.a src/drivers/rgbled/libdrivers__rgbled.a src/drivers/stm32/adc/libdrivers__adc.a src/drivers/stm32/tone_alarm/libdrivers__tone_alarm.a src/drivers/vmount/libdrivers__vmount.a src/modules/sensors/libmodules__sensors.a src/systemcmds/bl_update/libsystemcmds__bl_update.a src/systemcmds/hardfault_log/libsystemcmds__hardfault_log.a src/systemcmds/mixer/libsystemcmds__mixer.a src/systemcmds/mtd/libsystemcmds__mtd.a src/systemcmds/param/libsystemcmds__param.a src/systemcmds/perf/libsystemcmds__perf.a src/systemcmds/pwm/libsystemcmds__pwm.a src/systemcmds/reboot/libsystemcmds__reboot.a src/systemcmds/top/libsystemcmds__top.a src/systemcmds/tune_control/libsystemcmds__tune_control.a src/systemcmds/ver/libsystemcmds__ver.a src/modules/camera_feedback/libmodules__camera_feedback.a src/modules/commander/libmodules__commander.a src/modules/events/libmodules__events.a src/modules/land_detector/libmodules__land_detector.a src/modules/load_mon/libmake: *** [px4fmu-v2_default] Error 1
modules__load_mon.a src/modules/mavlink/libmodules__mavlink.a src/modules/navigator/libmodules__navigator.a src/modules/ekf2/libmodules__ekf2.a src/modules/fw_att_control/libmodules__fw_att_control.a src/modules/fw_pos_control_l1/libmodules__fw_pos_control_l1.a src/modules/mc_att_control/libmodules__mc_att_control.a src/modules/mc_pos_control/libmodules__mc_pos_control.a src/modules/vtol_att_control/libmodules__vtol_att_control.a src/modules/logger/libmodules__logger.a src/modules/dataman/libmodules__dataman.a src/modules/uORB/libmodules__uORB.a ROMFS/libromfs.a src/lib/drivers/airspeed/libdrivers__airspeed.a src/lib/led/libled.a src/lib/battery/libbattery.a src/lib/ecl/validation/libecl_validation.a src/lib/mixer/libmixer.a src/lib/tunes/libtunes.a src/lib/DriverFramework/framework/src/libdf_driver_framework.a src/lib/airspeed/libairspeed.a src/lib/ecl/EKF/libecl_EKF.a src/lib/ecl/geo_lookup/libecl_geo_lookup.a src/lib/ecl/attitude_fw/libecl_attitude_fw.a src/lib/landing_slope/liblanding_slope.a src/lib/ecl/l1/libecl_l1.a src/lib/ecl/tecs/libecl_tecs.a src/modules/fw_pos_control_l1/launchdetection/liblaunchdetection.a src/modules/fw_pos_control_l1/runway_takeoff/librunway_takeoff.a src/lib/circuit_breaker/libcircuit_breaker.a src/lib/conversion/libconversion.a src/lib/mathlib/libmathlib.a src/lib/ecl/geo/libecl_geo.a src/lib/controllib/libcontrollib.a src/lib/FlightTasks/libFlightTasks.a src/lib/FlightTasks/tasks/ManualAltitudeSmooth/libFlightTaskManualAltitudeSmooth.a src/lib/FlightTasks/tasks/ManualPositionSmooth/libFlightTaskManualPositionSmooth.a src/lib/FlightTasks/tasks/ManualPositionSmoothVel/libFlightTaskManualPositionSmoothVel.a src/lib/FlightTasks/tasks/ManualPosition/libFlightTaskManualPosition.a src/lib/FlightTasks/tasks/ManualAltitude/libFlightTaskManualAltitude.a src/lib/FlightTasks/tasks/Manual/libFlightTaskManual.a src/lib/FlightTasks/tasks/AutoLine/libFlightTaskAutoLine.a src/lib/FlightTasks/tasks/AutoMapper/libFlightTaskAutoMapper.a src/lib/FlightTasks/tasks/AutoLineSmoothVel/libFlightTaskAutoLineSmoothVel.a src/lib/FlightTasks/tasks/Utility/libFlightTaskUtility.a src/lib/FlightTasks/tasks/AutoMapper2/libFlightTaskAutoMapper2.a src/lib/FlightTasks/tasks/AutoFollowMe/libFlightTaskAutoFollowMe.a src/lib/FlightTasks/tasks/Auto/libFlightTaskAuto.a src/lib/FlightTasks/tasks/Offboard/libFlightTaskOffboard.a src/lib/FlightTasks/tasks/Failsafe/libFlightTaskFailsafe.a src/lib/FlightTasks/tasks/Transition/libFlightTaskTransition.a src/lib/FlightTasks/tasks/FlightTask/libFlightTask.a src/lib/WeatherVane/libWeatherVane.a src/lib/CollisionPrevention/libCollisionPrevention.a src/lib/pwm_limit/libpwm_limit.a src/lib/version/libversion.a src/platforms/common/libplatforms__common.a platforms/nuttx/src/px4_layer/libpx4_layer.a NuttX/nuttx/arch/arm/src/libarch.a src/drivers/boards/px4fmu-v2/libdrivers_board.a src/drivers/stm32/libdrivers_arch.a src/drivers/boards/common/libdrivers_boards_common.a src/drivers/boards/common/stm32/libdrivers_boards_common_arch.a src/modules/systemlib/libsystemlib.a src/lib/drivers/device/libdrivers__device.a src/lib/drivers/led/libdrivers__led.a src/lib/parameters/libparameters.a src/lib/cdev/libcdev.a src/lib/parameters/flashparams/libflashparams.a NuttX/nuttx/arch/arm/src/libarch.a src/drivers/boards/px4fmu-v2/libdrivers_board.a src/drivers/stm32/libdrivers_arch.a src/drivers/boards/common/libdrivers_boards_common.a src/drivers/boards/common/stm32/libdrivers_boards_common_arch.a src/modules/systemlib/libsystemlib.a src/lib/drivers/device/libdrivers__device.a src/lib/drivers/led/libdrivers__led.a src/lib/parameters/libparameters.a src/lib/cdev/libcdev.a src/lib/parameters/flashparams/libflashparams.a NuttX/apps/libapps.a src/lib/perf/libperf.a src/lib/parameters/tinybson/libtinybson.a NuttX/nuttx/libxx/libcxx.a NuttX/nuttx/libc/libc.a NuttX/nuttx/drivers/libdrivers.a NuttX/nuttx/fs/libfs.a NuttX/nuttx/mm/libmm.a NuttX/nuttx/sched/libsched.a -lm -lgcc msg/libuorb_msgs.a && :
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_fpclassify.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_fpclassify.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_cos.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_cos.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_sin.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_sin.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_atan.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_atan.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_ceil.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_ceil.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_cos.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_cos.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-wf_asin.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-wf_asin.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-wf_atan2.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-wf_atan2.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-wf_exp.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-wf_exp.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-wf_log.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-wf_log.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-wf_pow.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-wf_pow.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-e_acos.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-e_acos.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-e_asin.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-e_asin.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-k_cos.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-k_cos.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-k_rem_pio2.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-k_rem_pio2.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-k_sin.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-k_sin.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-kf_cos.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-kf_cos.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-kf_rem_pio2.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-kf_rem_pio2.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-kf_sin.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-kf_sin.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-kf_tan.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-kf_tan.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_atan.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_atan.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_fabs.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_fabs.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_finite.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_finite.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_floor.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_floor.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_lib_ver.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_lib_ver.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_matherr.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_matherr.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_nan.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_nan.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_rint.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_rint.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_scalbn.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_scalbn.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_finite.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_finite.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_nan.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_nan.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_scalbn.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_scalbn.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_copysign.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_copysign.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: nuttx_px4fmu-v2_default.elf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_copysign.o) does not
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-sf_copysign.o)
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: nuttx_px4fmu-v2_default.elf section .text' will not fit in region
flash'
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: address 0x8103890 of nuttx_px4fmu-v2_default.elf section __param' is not within region
flash'
flash'
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: region `flash' overflowed by 17985 bytes
collect2: error: ld returned 1 exit status
Makefile:176: recipe for target 'px4fmu-v2_default' failed
