I’m working on LPE with flow and lidar
and my lidar has a problem it keep shows
“lidar fault, beta” message
yes it seems quite noisy through QGC analyze like ± 4cm
but I don`t know why
it is connected through PWM
I’ve tested again with new lidar module to find out current module is broken but it is also noisy too
I also checked wire connection
my flow works crazy with this faulty lidar data
can I get some help?
If you have no distance data in the log, the lidar is not actually running. But then you would also not get “lidar fault” messages. Can you do a test to reproduce your problem and share a log?
