Hello i am new here i have a question about the GPS ublox M8n
recently i bought a new one but when i connect it to Pixhawk for the first Use, only a Blue led who flashes once and then stop
what i have to do ?
( i have Pixhawk V1)
@ismatitou
Hello
What you are seeing is normal.
When powered up the blue LED just flashes once, then nothing happens whilst the GPS searches for satellites, when it sees enough to get a ‘fix’ the blue LED flashes continuously to indicate it has a position location ‘fix’
That period of time (a few minutes depending on how good a view of the sky it has and when/where it got its last fix) is normal
HTH
Steve
Hi Stevie, I know it’s too old but I am stuck in my GPS ( ublox Neo-M8N) and when I go outside it didn’t turn blinking green, its big blue led is blinking always and the stich is blingking red.
Then I didn’t get the right outcomes from nsh (mavlink console) terminal, if you have a knowledge about it could you illuminate me please, because I finished all the issues about GPS in discuss forum but I didn’t find the solution:
nsh> gps status
INFO [gps] Main GPS
INFO [gps] protocol: UBX
INFO [gps] status: OK, port: /dev/ttyS0, baudrate: 115200
INFO [gps] sat info: disabled
INFO [gps] rate reading: 697 B/s
INFO [gps] rate position: 5.00 Hz
INFO [gps] rate velocity: 5.00 Hz
INFO [gps] rate publication: 5.00 Hz
INFO [gps] rate RTCM injection: 0.00 Hz
sensor_gps_s
timestamp: 72835397 (0.108428 seconds ago)
time_utc_usec: 1638873994399840
device_id: 11010053 (Type: 0xA8, SERIAL:0 (0x00))
lat: 410004809
lon: 291825571
alt: 179859
alt_ellipsoid: 217397
s_variance_m_s: 1000.0010
c_variance_rad: 3.1416
eph: 4294967.5000
epv: 4294967.5000
hdop: 99.9900
vdop: 99.9900
noise_per_ms: 102
jamming_indicator: 6
vel_m_s: 0.0000
vel_n_m_s: 0.0000
vel_e_m_s: 0.0000
vel_d_m_s: 0.0000
cog_rad: 0.0000
timestamp_time_relative: 0
heading: nan
heading_offset: 0.0000
automatic_gain_control: 1248
fix_type: 0
jamming_state: 0
vel_ned_valid: False
satellites_used: 0
