I have a Pixhawk 2.4.8 Flight Controller 32Bit 3DR 915Mhz Radio Telemetry M8N GPS My questionIs the Pixhawk 2.4.8 Flight Controller compatible with BLHeli-32 Dshot1200 ESC s
It should be compatible, yes.
Example of 1 4in 1 escs i was looking at https://www.ebay.com/itm/113052895253?ul_noapp=true
Am i right in this conclusion?
Spec s and features to the pixhawk
Features:
with external LED -Dual Size full angle LED
Advanced 32 bit ARM CortexM4 high performance processer, can operate NuttX RTOX
real time operation system
14 PWM/ Servo Output
Bus interface(UART,I2C,SPI,CAN)
Intergrated back up power and lose efficacy controller, main controller lose
efficacy can safely alter to back up control
Providing automatic and manual mode
Providing redundant power supply input and failover
Multicolor LED light
Providing multi sound buzzer interface
Micro SD records flying data
suit for:Quadcopter (450 500 550 650 ) Helicopter Airplane Car
Provide optical flow sensor, perfect fixed height indoor.
Free switching of fifteen flight modes
Supporting 2 GPS,achieve precise positioning
CPU:
32 bit 2M flash memory STM32F427 Cortex M4, with hardware floating point
processing unit
Main frequency: 168MHz,256K RAM
32 bit STM32F103 back up processor
Sensor:
L3GD20 3 axis digital 16 bit gyroscope
LSM303D 3 axis 14 acceleration/magnetometer
MPU6000 6 axis acceleration/magnetometer
Interface:
5 UART, one compatible high voltage, two have hardware flow control
Spektrum DSM/ DSM2/ DSM-X satellite receiver compatible input
Futaba SBUS compatible input and output
PPM signal input
RSSI(PWM or voltage) output
3.3 and 6.6VADC input
External MICRO USB interface
And your details listed below However i noticed the pixhawk is a 14 PWM/ Servo Output
and noticed that the ESC S are Supports Oneshot / Multishot / Dshot PWM
(I think the can be joined threw PWM?) they are also both 32 bit processors.
the Powerful 4in1 ESC with BLHELI32 firmware natively supports ESC Telemetry function.
Features:
4in1 ESC with 30.5x30.5mm mounting holes, supports DSHOT 1200, BLHELI32 firmware
On this version added more CAPS to reduce power noise
32bit ESC with BLHELI32 firmware
4PWM input
Voltage output (VBAT), ESC Telemetry(TELEM)
I am interested in your feedback
bob
Someone shared this with me seems to answer the question ( PWM) http://ardupilot.org/copter/docs/common-dshot.html
