I am trying to integrate an ADXL 345 accelerometer to the Pixhawk through I2C and I am not sure if I should make my own driver for it? Can someone point to the right direction as to how I integrate the sensor to the pixhawk?
A follow up: I plan to integrate 5 of these sensors to the PX4 firmware. When I did this on the teensy/arduino, I used a mux, do I do the same here too?
I am just getting started with the firmware development so any sort of help would go a long way.
Thank you so much for your reply. I was able to build the firmware and upload it on to my pixhawk.
I will look into the example drivers you directed me to and try to write up my own driver.
I do have another dumb question, once I have the driver, do I have to write a module which then talks to the sensor through the pixhawk (and then publishes uOrb messages)?
