I tried to use sonar with px4flow for position hold but I couldn’t.
I found that feature needs Local Position Estimator (LPE) running.
And when I tried to build with LPE module, the build fails.
Following is the cmake I tried.
# Estimation modules
modules/attitude_estimator_q
#modules/ekf2
modules/local_position_estimator
#modules/position_estimator_inav
#modules/landing_target_estimator
#modules/wind_estimator
When tried to build I got following errors
[517/569] Building CXX object src/modules/navigator/CMakeFiles/modules__navigator.dir/loiter.cpp.obj
FAILED: /home/dronedev/gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-g++ -DCONFIG_ARCH_BOARD_PX4FMU_V2 -DMODULE_NAME=\"navigator\" -DPX4_MAIN=navigator_app_main -D__DF_NUTTX -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -isystem NuttX/nuttx/include/cxx -isystem NuttX/nuttx/include -I. -Isrc -Isrc/lib -Isrc/modules -I../../src -I../../src/drivers/boards/px4fmu-v2 -I../../src/include -I../../src/lib -I../../src/lib/DriverFramework/framework/include -I../../src/lib/matrix -I../../src/modules -I../../src/platforms -INuttX/nuttx/arch/arm/src/armv7-m -INuttX/nuttx/arch/arm/src/chip -INuttX/nuttx/arch/arm/src/common -INuttX/apps/include -Iexternal/Install/include -I../../src/lib/ecl -fno-common -ffunction-sections -fdata-sections -mcpu=cortex-m4 -mthumb -march=armv7e-m -mfpu=fpv4-sp-d16 -mfloat-abi=hard -fno-common -ffunction-sections -fdata-sections -g -fno-exceptions -fno-rtti -std=gnu++11 -fno-threadsafe-statics -DCONFIG_WCHAR_BUILTIN -D__CUSTOM_FILE_IO__ -fcheck-new -Wall -Wextra -Werror -Warray-bounds -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wmissing-declarations -Wmissing-field-initializers -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-implicit-fallthrough -Wno-missing-include-dirs -Wno-unused-parameter -Wunused-but-set-variable -Wformat=1 -Wno-missing-field-initializers -Wno-overloaded-virtual -Wreorder -Wno-format-truncation -fvisibility=hidden -include /home/dronedev/workspace/px4/Firmware/src/include/visibility.h -fno-strict-aliasing -fomit-frame-pointer -fno-math-errno -funsafe-math-optimizations -ffunction-sections -fdata-sections -fno-strength-reduce -fno-builtin-printf -Os -DNDEBUG -fno-strict-aliasing -fomit-frame-pointer -fno-math-errno -funsafe-math-optimizations -ffunction-sections -fdata-sections -fno-strength-reduce -fno-builtin-printf -Wframe-larger-than=1300 -MMD -MT src/modules/navigator/CMakeFiles/modules__navigator.dir/navigator_main.cpp.obj -MF src/modules/navigator/CMakeFiles/modules__navigator.dir/navigator_main.cpp.obj.d -o src/modules/navigator/CMakeFiles/modules__navigator.dir/navigator_main.cpp.obj -c ../../src/modules/navigator/navigator_main.cpp
In file included from ../../src/platforms/px4_param.h:42:0,
from ../../src/platforms/px4_module_params.h:44,
from ../../src/modules/navigator/datalinkloss.h:42,
from ../../src/modules/navigator/navigator.h:44,
from ../../src/modules/navigator/navigator_main.cpp:46:
../../src/modules/navigator/navigator.h:354:28: error: 'VT_B_DEC_MSS' is not a member of 'px4::params'
(ParamFloat<px4::params::VT_B_DEC_MSS>) _param_back_trans_dec_mss,
../../src/platforms/px4_param_macros.h:239:18: note: in definition of macro 'REM'
#define REM(...) __VA_ARGS__
../../src/platforms/px4_param.h:58:40: note: in expansion of macro 'PAIR'
do_not_explicitly_use_this_namespace::PAIR(x);
../../src/platforms/px4_param_macros.h:55:150: note: in expansion of macro '_DEFINE_SINGLE_PARAMETER'
#define APPLY12(t, aaa, aab, aac, aad, aae, aaf, aag, aah, aai, aaj, aak, aal) t(aaa) t(aab) t(aac) t(aad) t(aae) t(aaf) t(aag) t(aah) t(aai) t(aaj) t(aak) t(aal)
../../src/platforms/px4_param_macros.h:197:33: note: in expansion of macro 'APPLY12'
#define APPLY_ALL_H3(t, n, ...) APPLY##n(t, __VA_ARGS__)
../../src/platforms/px4_param_macros.h:198:33: note: in expansion of macro 'APPLY_ALL_H3'
#define APPLY_ALL_H2(t, n, ...) APPLY_ALL_H3(t, n, __VA_ARGS__)
../../src/platforms/px4_param_macros.h:199:27: note: in expansion of macro 'APPLY_ALL_H2'
#define APPLY_ALL(t, ...) APPLY_ALL_H2(t, NUM_ARGS(__VA_ARGS__), __VA_ARGS__)
../../src/platforms/px4_param.h:79:2: note: in expansion of macro 'APPLY_ALL'
APPLY_ALL(_DEFINE_SINGLE_PARAMETER, __VA_ARGS__) \
../../src/modules/navigator/navigator.h:336:2: note: in expansion of macro 'DEFINE_PARAMETERS'
DEFINE_PARAMETERS(
compilation terminated due to -Wfatal-errors.
FAILED: /home/dronedev/gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-g++ -DCONFIG_ARCH_BOARD_PX4FMU_V2 -DMODULE_NAME=\"navigator\" -DPX4_MAIN=navigator_app_main -D__DF_NUTTX -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -isystem NuttX/nuttx/include/cxx -isystem NuttX/nuttx/include -I. -Isrc -Isrc/lib -Isrc/modules -I../../src -I../../src/drivers/boards/px4fmu-v2 -I../../src/include -I../../src/lib -I../../src/lib/DriverFramework/framework/include -I../../src/lib/matrix -I../../src/modules -I../../src/platforms -INuttX/nuttx/arch/arm/src/armv7-m -INuttX/nuttx/arch/arm/src/chip -INuttX/nuttx/arch/arm/src/common -INuttX/apps/include -Iexternal/Install/include -I../../src/lib/ecl -fno-common -ffunction-sections -fdata-sections -mcpu=cortex-m4 -mthumb -march=armv7e-m -mfpu=fpv4-sp-d16 -mfloat-abi=hard -fno-common -ffunction-sections -fdata-sections -g -fno-exceptions -fno-rtti -std=gnu++11 -fno-threadsafe-statics -DCONFIG_WCHAR_BUILTIN -D__CUSTOM_FILE_IO__ -fcheck-new -Wall -Wextra -Werror -Warray-bounds -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wmissing-declarations -Wmissing-field-initializers -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-implicit-fallthrough -Wno-missing-include-dirs -Wno-unused-parameter -Wunused-but-set-variable -Wformat=1 -Wno-missing-field-initializers -Wno-overloaded-virtual -Wreorder -Wno-format-truncation -fvisibility=hidden -include /home/dronedev/workspace/px4/Firmware/src/include/visibility.h -fno-strict-aliasing -fomit-frame-pointer -fno-math-errno -funsafe-math-optimizations -ffunction-sections -fdata-sections -fno-strength-reduce -fno-builtin-printf -Os -DNDEBUG -fno-strict-aliasing -fomit-frame-pointer -fno-math-errno -funsafe-math-optimizations -ffunction-sections -fdata-sections -fno-strength-reduce -fno-builtin-printf -Wframe-larger-than=1300 -MMD -MT src/modules/navigator/CMakeFiles/modules__navigator.dir/loiter.cpp.obj -MF src/modules/navigator/CMakeFiles/modules__navigator.dir/loiter.cpp.obj.d -o src/modules/navigator/CMakeFiles/modules__navigator.dir/loiter.cpp.obj -c ../../src/modules/navigator/loiter.cpp
from ../../src/modules/navigator/loiter.h:46,
from ../../src/modules/navigator/loiter.cpp:42:
DEFINE_PARAMETERS(
FAILED: /home/dronedev/gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-g++ -DCONFIG_ARCH_BOARD_PX4FMU_V2 -DMODULE_NAME=\"navigator\" -DPX4_MAIN=navigator_app_main -D__DF_NUTTX -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -isystem NuttX/nuttx/include/cxx -isystem NuttX/nuttx/include -I. -Isrc -Isrc/lib -Isrc/modules -I../../src -I../../src/drivers/boards/px4fmu-v2 -I../../src/include -I../../src/lib -I../../src/lib/DriverFramework/framework/include -I../../src/lib/matrix -I../../src/modules -I../../src/platforms -INuttX/nuttx/arch/arm/src/armv7-m -INuttX/nuttx/arch/arm/src/chip -INuttX/nuttx/arch/arm/src/common -INuttX/apps/include -Iexternal/Install/include -I../../src/lib/ecl -fno-common -ffunction-sections -fdata-sections -mcpu=cortex-m4 -mthumb -march=armv7e-m -mfpu=fpv4-sp-d16 -mfloat-abi=hard -fno-common -ffunction-sections -fdata-sections -g -fno-exceptions -fno-rtti -std=gnu++11 -fno-threadsafe-statics -DCONFIG_WCHAR_BUILTIN -D__CUSTOM_FILE_IO__ -fcheck-new -Wall -Wextra -Werror -Warray-bounds -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wmissing-declarations -Wmissing-field-initializers -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-implicit-fallthrough -Wno-missing-include-dirs -Wno-unused-parameter -Wunused-but-set-variable -Wformat=1 -Wno-missing-field-initializers -Wno-overloaded-virtual -Wreorder -Wno-format-truncation -fvisibility=hidden -include /home/dronedev/workspace/px4/Firmware/src/include/visibility.h -fno-strict-aliasing -fomit-frame-pointer -fno-math-errno -funsafe-math-optimizations -ffunction-sections -fdata-sections -fno-strength-reduce -fno-builtin-printf -Os -DNDEBUG -fno-strict-aliasing -fomit-frame-pointer -fno-math-errno -funsafe-math-optimizations -ffunction-sections -fdata-sections -fno-strength-reduce -fno-builtin-printf -Wframe-larger-than=1300 -MMD -MT src/modules/navigator/CMakeFiles/modules__navigator.dir/mission.cpp.obj -MF src/modules/navigator/CMakeFiles/modules__navigator.dir/mission.cpp.obj.d -o src/modules/navigator/CMakeFiles/modules__navigator.dir/mission.cpp.obj -c ../../src/modules/navigator/mission.cpp
from ../../src/modules/navigator/mission.h:55,
from ../../src/modules/navigator/mission.cpp:48:
DEFINE_PARAMETERS(
Makefile:154: recipe for target 'px4fmu-v2_default' failed
make: *** [px4fmu-v2_default] Error 1
