I am programming a custom drone which uses the MAVLink protocol but no known autopilot. I was able to display some common data in QGroundControl like the attitude or battery remaining capacity.
But I would like to be able to display other information like mount orientation for instance. I know the message is recognised because I can display the info in the Analyse widget. What I would like to do is to display these info in the navigation widget (the one with the compass) or in another custom widget. Is it possible? How can I do that?
For instance, the mount orientation is using the MOUNT_ORIENTATION message.
I have access to QGroundControl source code if I need to modify it.
Then how is it that different vehicules (i.e quadcopter, sub, rover…) have different fact groups? I have already used a submarine from bluerobotics and I had access to more information like gain and camera offset right beneath the compass.
