I have a problem in installing QGC.
When I install and load qgc then every menu does not appear properly. For example, ‘File’ menu contains only 2 choices (qgcerr1.png), and the vehicle set up icon allows me to get to only 2 menus (qgcerr1.png). I installed QGC 3.3.2 in my Windows 10 build 15063.1155, and had downloaded and installed a windows installation execution file from qgc hompage.
Could you please share how I can install it properly? Thank you
I also facing the same situation when I tried to install QGC but at the installation time it shows an error windows defender error 577, so I want a proper solution how can I install QGC properly without facing any error.
