I am trying to use the pixhawk purely as an interface to control my motors. I have it connected via serial to an offboard TX1 which is running the controller, and am trying to send actuator commands to my quadrotor motors via the pixhawk. I know there may be a significant amount of latency with this setup, but for now I don’t really care about that.
Now in order to control the motors I have been trying to use the actuator control message as seen in this example.
https://pixhawk.org/dev/ros/ground_rover
I have updated the code and have had success with it working. However, in this example the actuator control message he is sending is still sending r,p,y and throttle, whereas I want to control the motors individually.
Now in order to do this it seems like I need to change the mixer on in order to just passthrough the direct motors commands. On actuator_msg channel 0,1,2,3. However, how I am supposed to do this is what I am stuck on? I have tried this two ways.
The first thing I was to load the mixer via the mavlink console in qgroundcontrol. Using this command
mixer load /dev/pwm_output0 /etc/mixers/FMU_pass.mix
I then run my above code, but my motors do not spin. However, by running
pwm info -d /dev/pwm_output0
I am able to see that my pwm values have changed.
I have also tried it on dev/pwm_output1.
Due to the pwm values changing in the console I believe I am on the right track, but am just missing one or two extra steps which I can not seem to figure out.
The other way I have attempted this is to is to create a new file in init.d and have that load the FMU_Pass.mix and then load that configuration onto the board. That also ended in failure though.
So if anyone has any idea on what steps I may be missing I would appreciate the help. Also if you know a better way to send direct motor commands rather then messing with mixer values, then I am all ears.
