How can I use dronecore on Raspberry pi?
Currently Iโ€™ve downloaded dronecode library from github and tried to build on Raspberry pi 3 for off board control.
But in build time, Raspberry pi(Ubuntu Mate) is locked up.
Do you have any solution?
I tried to install the DroneCore on Raspberrypi 2B, and I also found a problem about tinyxml2, just as follows. That means I have to install the tinyxml2 lib on the Pi firstly?
I have solved such problem. DroneCore is installed on my RaspberryPi 2B successfully, as shown in the Figure.
Thank you for infomation.
Could you please share the command or instruction for this build?
hey @kevinjhur,
I show you the process of installation. would you please share the topology of the RaspberryPi connecting to the pixhawk with me?
Iโ€™m trying the following application process of the DroneCore for the real vehicle.
We can share the exploration process, do you agree?
After โ€˜git submodule update --init --recursiveโ€™ then
three steps need to implement:
1.
pi@raspberrypi:~ $ sudo apt-get install libtinyxml2-dev
Reading package listsโ€ฆ Done
Building dependency tree
Reading state informationโ€ฆ Done
The following extra packages will be installed:
libtinyxml2-2
The following NEW packages will be installed:
libtinyxml2-2 libtinyxml2-dev
0 upgraded, 2 newly installed, 0 to remove and 303 not upgraded.
Need to get 55.4 kB of archives.
After this operation, 245 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libtinyxml2-2 armhf 2.2.0-1 [21.4 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libtinyxml2-dev armhf 2.2.0-1 [34.0 kB]
Fetched 55.4 kB in 2s (26.6 kB/s)
Selecting previously unselected package libtinyxml2-2:armhf.
(Reading database โ€ฆ 122757 files and directories currently installed.)
Preparing to unpack โ€ฆ/libtinyxml2-2_2.2.0-1_armhf.deb โ€ฆ
Unpacking libtinyxml2-2:armhf (2.2.0-1) โ€ฆ
Selecting previously unselected package libtinyxml2-dev:armhf.
Preparing to unpack โ€ฆ/libtinyxml2-dev_2.2.0-1_armhf.deb โ€ฆ
Unpacking libtinyxml2-dev:armhf (2.2.0-1) โ€ฆ
Setting up libtinyxml2-2:armhf (2.2.0-1) โ€ฆ
Setting up libtinyxml2-dev:armhf (2.2.0-1) โ€ฆ
Processing triggers for libc-bin (2.19-18+deb8u6) โ€ฆ
pi@raspberrypi:~ $ cd DroneCore
pi@raspberrypi:~/DroneCore $ make clean
pi@raspberrypi:~/DroneCore $ make default
โ€“ The C compiler identification is GNU 4.9.2
โ€“ The CXX compiler identification is GNU 4.9.2
โ€“ Check for working C compiler: /usr/bin/cc
โ€“ Check for working C compiler: /usr/bin/cc โ€“ works
โ€“ Detecting C compiler ABI info
โ€“ Detecting C compiler ABI info - done
โ€“ Detecting C compile features
โ€“ Detecting C compile features - done
โ€“ Check for working CXX compiler: /usr/bin/c++
โ€“ Check for working CXX compiler: /usr/bin/c++ โ€“ works
โ€“ Detecting CXX compiler ABI info
โ€“ Detecting CXX compiler ABI info - done
โ€“ Detecting CXX compile features
โ€“ Detecting CXX compile features - done
โ€“ Looking for sys/types.h
โ€“ Looking for sys/types.h - found
โ€“ Looking for stdint.h
โ€“ Looking for stdint.h - found
โ€“ Looking for stddef.h
โ€“ Looking for stddef.h - found
โ€“ Check size of off64_t
โ€“ Check size of off64_t - done
โ€“ Looking for fseeko
โ€“ Looking for fseeko - found
โ€“ Looking for unistd.h
โ€“ Looking for unistd.h - found
โ€“ Found CURL: /usr/lib/arm-linux-gnueabihf/libcurl.so (found version โ€œ7.38.0โ€)
โ€“ Looking for pthread.h
โ€“ Looking for pthread.h - found
โ€“ Looking for pthread_create
โ€“ Looking for pthread_create - not found
โ€“ Looking for pthread_create in pthreads
โ€“ Looking for pthread_create in pthreads - not found
โ€“ Looking for pthread_create in pthread - found
โ€“ Found Threads: TRUE
โ€“ Performing Test _flag_supported
โ€“ Performing Test _flag_supported - Failed
โ€“ BUILD_DRONECORESERVER not set: not building dronecore server
โ€“ Found PythonInterp: /usr/bin/python (found version โ€œ2.7.9โ€)
โ€“ Check if compiler accepts -pthread
โ€“ Check if compiler accepts -pthread - yes
โ€“ Configuring done
โ€“ Generating done
โ€“ Build files have been written to: /home/pi/DroneCore/build/default
Build dir: build/default
Scanning dependencies of target gtest
Scanning dependencies of target zlibstatic
Scanning dependencies of target json11
Scanning dependencies of target gmock
[ 1%] Building CXX object plugins/mission/third_party/json11/CMakeFiles/json11.dir/json11.cpp.o
[ 2%] Building C object third_party/zlib/CMakeFiles/zlib.dir/adler32.o
[ 2%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/compress.o
[ 3%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/crc32.o
[ 4%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/deflate.o
[ 5%] Building CXX object third_party/gtest/googlemock/gtest/CMakeFiles/gtest.dir/src/gtest-all.cc.o
[ 6%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/adler32.o
[ 7%] Building CXX object third_party/gtest/googlemock/CMakeFiles/gmock.dir//googletest/src/gtest-all.cc.o
[ 7%] Building CXX object third_party/gtest/googlemock/CMakeFiles/gmock.dir/src/gmock-all.cc.o
[ 8%] Building C object third_party/zlib/CMakeFiles/zlib.dir/compress.o
[ 9%] Building C object third_party/zlib/CMakeFiles/zlib.dir/crc32.o
[ 10%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/gzclose.o
[ 10%] Building C object third_party/zlib/CMakeFiles/zlib.dir/deflate.o
[ 11%] Building C object third_party/zlib/CMakeFiles/zlib.dir/gzclose.o
[ 12%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/gzlib.o
[ 13%] Building C object third_party/zlib/CMakeFiles/zlib.dir/gzlib.o
[ 14%] Building C object third_party/zlib/CMakeFiles/zlib.dir/gzread.o
[ 15%] Building C object third_party/zlib/CMakeFiles/zlib.dir/gzwrite.o
[ 15%] Building C object third_party/zlib/CMakeFiles/zlib.dir/inflate.o
[ 15%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/gzread.o
[ 16%] Building C object third_party/zlib/CMakeFiles/zlib.dir/infback.o
[ 18%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/gzwrite.o
[ 18%] Building C object third_party/zlib/CMakeFiles/zlib.dir/inftrees.o
[ 19%] Building C object third_party/zlib/CMakeFiles/zlib.dir/inffast.o
[ 20%] Building C object third_party/zlib/CMakeFiles/zlib.dir/trees.o
[ 20%] Building C object third_party/zlib/CMakeFiles/zlib.dir/uncompr.o
[ 21%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/inflate.o
[ 22%] Building C object third_party/zlib/CMakeFiles/zlib.dir/zutil.o
[ 23%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/infback.o
[ 24%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/inftrees.o
[ 24%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/inffast.o
[ 25%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/trees.o
[ 26%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/uncompr.o
[ 27%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/zutil.o
[ 28%] Linking C shared library libz.so
[ 28%] Built target zlib
Scanning dependencies of target minigzip
Scanning dependencies of target example
Scanning dependencies of target example64
[ 29%] Building C object third_party/zlib/CMakeFiles/minigzip.dir/test/minigzip.o
[ 30%] Building C object third_party/zlib/CMakeFiles/example.dir/test/example.o
[ 31%] Building C object third_party/zlib/CMakeFiles/example64.dir/test/example.o
[ 32%] Linking C static library libz.a
[ 32%] Linking C executable minigzip
[ 32%] Built target zlibstatic
Scanning dependencies of target minigzip64
[ 32%] Built target minigzip
[ 32%] Linking C executable example
[ 34%] Building C object third_party/zlib/CMakeFiles/minigzip64.dir/test/minigzip.o
[ 35%] Linking C executable example64
Scanning dependencies of target dronecore
[ 35%] Built target example
[ 35%] Built target example64
[ 36%] Linking C executable minigzip64
[ 36%] Built target minigzip64
[ 36%] Building CXX object core/CMakeFiles/dronecore.dir/call_every_handler.cpp.o
[ 37%] Building CXX object core/CMakeFiles/dronecore.dir/connection.cpp.o
[ 38%] Building CXX object core/CMakeFiles/dronecore.dir/device.cpp.o
[ 39%] Building CXX object core/CMakeFiles/dronecore.dir/curl_wrapper.cpp.o
[ 40%] Building CXX object core/CMakeFiles/dronecore.dir/dronecore.cpp.o
[ 40%] Building CXX object core/CMakeFiles/dronecore.dir/dronecore_impl.cpp.o
[ 41%] Linking CXX static library libjson11.a
[ 41%] Built target json11
[ 42%] Building CXX object core/CMakeFiles/dronecore.dir/global_include.cpp.o
[ 44%] Building CXX object core/CMakeFiles/dronecore.dir/mavlink_commands.cpp.o
[ 44%] Building CXX object core/CMakeFiles/dronecore.dir/http_loader.cpp.o
[ 44%] Building CXX object core/CMakeFiles/dronecore.dir/mavlink_parameters.cpp.o
[ 45%] Building CXX object core/CMakeFiles/dronecore.dir/mavlink_channels.cpp.o
[ 46%] Building CXX object core/CMakeFiles/dronecore.dir/mavlink_receiver.cpp.o
[ 47%] Building CXX object core/CMakeFiles/dronecore.dir/plugin_base.cpp.o
[ 48%] Building CXX object core/CMakeFiles/dronecore.dir/plugin_impl_base.cpp.o
[ 48%] Building CXX object core/CMakeFiles/dronecore.dir/serial_connection.cpp.o
[ 49%] Linking CXX static library libgmockd.a
[ 50%] Building CXX object core/CMakeFiles/dronecore.dir/tcp_connection.cpp.o
[ 51%] Building CXX object core/CMakeFiles/dronecore.dir/timeout_handler.cpp.o
[ 52%] Building CXX object core/CMakeFiles/dronecore.dir/udp_connection.cpp.o
[ 53%] Linking CXX static library libgtestd.a
[ 53%] Built target gmock
[ 53%] Built target gtest
Scanning dependencies of target gtest_main
[ 54%] Building CXX object third_party/gtest/googlemock/gtest/CMakeFiles/gtest_main.dir/src/gtest_main.cc.o
[ 54%] Linking CXX shared library libdronecore.so
[ 54%] Built target dronecore
Scanning dependencies of target dronecore_gimbal
Scanning dependencies of target dronecore_mission
Scanning dependencies of target dronecore_action
Scanning dependencies of target dronecore_telemetry
Scanning dependencies of target dronecore_logging
Scanning dependencies of target dronecore_offboard
Scanning dependencies of target dronecore_info
[ 54%] Building CXX object plugins/info/CMakeFiles/dronecore_info.dir/info.cpp.o
[ 54%] Building CXX object plugins/telemetry/CMakeFiles/dronecore_telemetry.dir/telemetry.cpp.o
[ 55%] Building CXX object plugins/offboard/CMakeFiles/dronecore_offboard.dir/offboard.cpp.o
[ 56%] Building CXX object plugins/gimbal/CMakeFiles/dronecore_gimbal.dir/gimbal.cpp.o
[ 57%] Building CXX object plugins/logging/CMakeFiles/dronecore_logging.dir/logging.cpp.o
[ 58%] Building CXX object plugins/action/CMakeFiles/dronecore_action.dir/action.cpp.o
[ 59%] Building CXX object plugins/mission/CMakeFiles/dronecore_mission.dir/mission.cpp.o
[ 60%] Linking CXX static library libgtest_maind.a
[ 60%] Built target gtest_main
[ 61%] Building CXX object plugins/mission/CMakeFiles/dronecore_mission.dir/mission_impl.cpp.o
[ 62%] Building CXX object plugins/info/CMakeFiles/dronecore_info.dir/info_impl.cpp.o
[ 63%] Building CXX object plugins/gimbal/CMakeFiles/dronecore_gimbal.dir/gimbal_impl.cpp.o
[ 63%] Building CXX object plugins/logging/CMakeFiles/dronecore_logging.dir/logging_impl.cpp.o
[ 64%] Building CXX object plugins/offboard/CMakeFiles/dronecore_offboard.dir/offboard_impl.cpp.o
[ 65%] Building CXX object plugins/telemetry/CMakeFiles/dronecore_telemetry.dir/telemetry_impl.cpp.o
[ 67%] Building CXX object plugins/action/CMakeFiles/dronecore_action.dir/action_impl.cpp.o
Scanning dependencies of target dronecore_follow_me
[ 68%] Building CXX object plugins/follow_me/CMakeFiles/dronecore_follow_me.dir/follow_me.cpp.o
[ 69%] Linking CXX shared library libdronecore_info.so
[ 69%] Built target dronecore_info
[ 70%] Building CXX object plugins/mission/CMakeFiles/dronecore_mission.dir/mission_item.cpp.o
[ 71%] Linking CXX shared library libdronecore_gimbal.so
[ 71%] Building CXX object plugins/follow_me/CMakeFiles/dronecore_follow_me.dir/follow_me_impl.cpp.o
[ 72%] Linking CXX shared library libdronecore_logging.so
[ 73%] Building CXX object plugins/telemetry/CMakeFiles/dronecore_telemetry.dir/math_conversions.cpp.o
[ 73%] Built target dronecore_gimbal
[ 73%] Building CXX object plugins/mission/CMakeFiles/dronecore_mission.dir/mission_item_impl.cpp.o
[ 73%] Built target dronecore_logging
[ 74%] Linking CXX shared library libdronecore_offboard.so
[ 75%] Linking CXX shared library libdronecore_action.so
[ 75%] Built target dronecore_offboard
[ 76%] Linking CXX shared library libdronecore_telemetry.so
[ 76%] Built target dronecore_action
[ 76%] Built target dronecore_telemetry
[ 77%] Linking CXX shared library libdronecore_mission.so
[ 77%] Built target dronecore_mission
Scanning dependencies of target unit_tests_runner
[ 78%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/mavlink_channels_test.cpp.o
[ 78%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/unittests_main.cpp.o
[ 79%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/curl_test.cpp.o
[ 80%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/global_include_test.cpp.o
[ 81%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/call_every_handler_test.cpp.o
[ 82%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/timeout_handler_test.cpp.o
[ 83%] Building CXX object CMakeFiles/unit_tests_runner.dir/plugins/mission/mission_import_qgc_test.cpp.o
[ 84%] Linking CXX shared library libdronecore_follow_me.so
[ 84%] Built target dronecore_follow_me
Scanning dependencies of target integration_tests_runner
[ 84%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/
[ 85%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/simple_connect.cpp.o
[ 86%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/async_connect.cpp.o
[ 87%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/telemetry_simple.cpp.o
[ 88%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/telemetry_modes.cpp.o
[ 89%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/telemetry_health.cpp.o
[ 89%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/telemetry_async.cpp.o
[ 90%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/simple_hover.cpp.o
[ 90%] Linking CXX executable unit_tests_runner
[ 91%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/async_hover.cpp.o
[ 91%] Built target unit_tests_runner
[ 91%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/takeoff_and_kill.cpp.o
[ 92%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/offboard_velocity.cpp.o
[ 93%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/logging.cpp.o
[ 94%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/info.cpp.o
[ 95%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/mission.cpp.o
[ 95%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/mission_change_speed.cpp.o
[ 96%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/mission_survey.cpp.o
[ 97%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/gimbal.cpp.o
[ 98%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/transition_multicopter_fixedwing.cpp.o
[ 98%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/follow_me.cpp.o
[100%] Linking CXX executable integration_tests_runner
[100%] Built target integration_tests_runner
pi@raspberrypi:~/DroneCore $ sudo INSTALL_PREFIX=/usr/local make default install-- The C compiler identification is GNU 4.9.2
โ€“ Generating done
[ 2%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/adler32.o
[ 3%] Building C object third_party/zlib/CMakeFiles/zlib.dir/compress.o
[ 4%] Building C object third_party/zlib/CMakeFiles/zlib.dir/adler32.o
[ 4%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/compress.o
[ 6%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/crc32.o
[ 8%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/deflate.o
[ 11%] Building C object third_party/zlib/CMakeFiles/zlib.dir/deflate.o
[ 11%] Building CXX object third_party/gtest/googlemock/CMakeFiles/gmock.dir/src/gmock-all.cc.o
[ 12%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/gzread.o
[ 15%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/gzwrite.o
[ 16%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/inflate.o
[ 17%] Building C object third_party/zlib/CMakeFiles/zlib.dir/gzwrite.o
[ 18%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/infback.o
[ 18%] Building C object third_party/zlib/CMakeFiles/zlib.dir/inflate.o
[ 19%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/inftrees.o
[ 19%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/inffast.o
[ 20%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/trees.o
[ 21%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/uncompr.o
[ 22%] Building C object third_party/zlib/CMakeFiles/zlibstatic.dir/zutil.o
[ 23%] Building C object third_party/zlib/CMakeFiles/zlib.dir/infback.o
[ 24%] Building C object third_party/zlib/CMakeFiles/zlib.dir/inftrees.o
[ 25%] Building C object third_party/zlib/CMakeFiles/zlib.dir/inffast.o
[ 26%] Building C object third_party/zlib/CMakeFiles/zlib.dir/trees.o
[ 26%] Building C object third_party/zlib/CMakeFiles/zlib.dir/uncompr.o
[ 27%] Building C object third_party/zlib/CMakeFiles/zlib.dir/zutil.o
[ 28%] Linking C static library libz.a
[ 29%] Linking C shared library libz.so
[ 29%] Built target zlibstatic
[ 32%] Building C object third_party/zlib/CMakeFiles/minigzip.dir/test/minigzip.o
[ 32%] Building CXX object core/CMakeFiles/dronecore.dir/call_every_handler.cpp.o
[ 34%] Linking C executable example64
[ 34%] Linking C executable minigzip
[ 34%] Built target example64
[ 35%] Building CXX object core/CMakeFiles/dronecore.dir/connection.cpp.o
[ 35%] Built target minigzip
[ 36%] Building CXX object core/CMakeFiles/dronecore.dir/curl_wrapper.cpp.o
[ 37%] Building C object third_party/zlib/CMakeFiles/minigzip64.dir/test/minigzip.o
[ 38%] Linking C executable minigzip64
[ 39%] Linking CXX static library libjson11.a
[ 39%] Built target minigzip64
[ 40%] Building CXX object core/CMakeFiles/dronecore.dir/device.cpp.o
[ 40%] Built target json11
[ 41%] Building CXX object core/CMakeFiles/dronecore.dir/dronecore_impl.cpp.o
[ 43%] Building CXX object core/CMakeFiles/dronecore.dir/http_loader.cpp.o
[ 45%] Building CXX object core/CMakeFiles/dronecore.dir/mavlink_commands.cpp.o
[ 49%] Building CXX object core/CMakeFiles/dronecore.dir/tcp_connection.cpp.o
[ 50%] Building CXX object core/CMakeFiles/dronecore.dir/timeout_handler.cpp.o
[ 51%] Building CXX object core/CMakeFiles/dronecore.dir/udp_connection.cpp.o
[ 52%] Linking CXX static library libgtestd.a
[ 53%] Linking CXX static library libgmockd.a
[ 53%] Linking CXX shared library libdronecore.so
[ 56%] Building CXX object plugins/offboard/CMakeFiles/dronecore_offboard.dir/offboard.cpp.o
[ 57%] Building CXX object plugins/action/CMakeFiles/dronecore_action.dir/action.cpp.o
[ 58%] Building CXX object plugins/logging/CMakeFiles/dronecore_logging.dir/logging.cpp.o
[ 58%] Building CXX object plugins/info/CMakeFiles/dronecore_info.dir/info.cpp.o
[ 58%] Building CXX object plugins/telemetry/CMakeFiles/dronecore_telemetry.dir/telemetry.cpp.o
[ 60%] Building CXX object plugins/info/CMakeFiles/dronecore_info.dir/info_impl.cpp.o
[ 61%] Linking CXX static library libgtest_maind.a
[ 62%] Building CXX object plugins/gimbal/CMakeFiles/dronecore_gimbal.dir/gimbal_impl.cpp.o
[ 63%] Building CXX object plugins/telemetry/CMakeFiles/dronecore_telemetry.dir/telemetry_impl.cpp.o
[ 64%] Building CXX object plugins/mission/CMakeFiles/dronecore_mission.dir/mission_impl.cpp.o
[ 65%] Building CXX object plugins/action/CMakeFiles/dronecore_action.dir/action_impl.cpp.o
[ 67%] Building CXX object plugins/offboard/CMakeFiles/dronecore_offboard.dir/offboard_impl.cpp.o
[ 67%] Built target gtest_main
[ 70%] Building CXX object plugins/telemetry/CMakeFiles/dronecore_telemetry.dir/math_conversions.cpp.o
[ 71%] Built target dronecore_gimbal
[ 72%] Building CXX object plugins/mission/CMakeFiles/dronecore_mission.dir/mission_item.cpp.o
[ 72%] Building CXX object plugins/follow_me/CMakeFiles/dronecore_follow_me.dir/follow_me_impl.cpp.o
[ 73%] Linking CXX shared library libdronecore_logging.so
[ 74%] Built target dronecore_offboard
[ 75%] Linking CXX shared library libdronecore_telemetry.so
[ 76%] Linking CXX shared library libdronecore_action.so
[ 77%] Linking CXX shared library libdronecore_follow_me.so
[ 78%] Linking CXX shared library libdronecore_mission.so
[ 78%] Built target dronecore_follow_me
[ 78%] Built target dronecore_mission
[ 79%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/mavlink_channels_test.cpp.o
[ 79%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/
[ 80%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/async_connect.cpp.o
[ 80%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/unittests_main.cpp.o
[ 82%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/global_include_test.cpp.o
[ 82%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/call_every_handler_test.cpp.o
[ 83%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/timeout_handler_test.cpp.o
[ 84%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/simple_connect.cpp.o
[ 86%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/simple_hover.cpp.o
[ 86%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/telemetry_simple.cpp.o
[ 87%] Building CXX object CMakeFiles/unit_tests_runner.dir/core/curl_test.cpp.o
[ 89%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/telemetry_modes.cpp.o
[ 90%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/telemetry_health.cpp.o
[ 89%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/async_hover.cpp.o
[ 91%] Building CXX object CMakeFiles/unit_tests_runner.dir/plugins/mission/mission_import_qgc_test.cpp.o
[ 93%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/info.cpp.o
[ 94%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/mission.cpp.o
[ 95%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/logging.cpp.o
[ 94%] Building CXX object integration_tests/CMakeFiles/integration_tests_runner.dir/mission_change_speed.cpp.o
[ 95%] Linking CXX executable unit_tests_runner
[ 96%] Built target unit_tests_runner
Install the projectโ€ฆ
โ€“ Install configuration: โ€œDebugโ€
โ€“ Installing: /usr/local/lib/libdronecore.so
โ€“ Installing: /usr/local/include/dronecore/dronecore.h
โ€“ Installing: /usr/local/include/dronecore/device.h
โ€“ Installing: /usr/local/include/dronecore/plugin_base.h
โ€“ Installing: /usr/local/include/dronecore/action.h
โ€“ Installing: /usr/local/lib/libdronecore_action.so
โ€“ Set runtime path of โ€œ/usr/local/lib/libdronecore_action.soโ€ to โ€œโ€
โ€“ Installing: /usr/local/include/dronecore/gimbal.h
โ€“ Installing: /usr/local/lib/libdronecore_gimbal.so
โ€“ Set runtime path of โ€œ/usr/local/lib/libdronecore_gimbal.soโ€ to โ€œโ€
โ€“ Installing: /usr/local/include/dronecore/mission.h
โ€“ Installing: /usr/local/include/dronecore/mission_item.h
โ€“ Installing: /usr/local/lib/libdronecore_mission.so
โ€“ Set runtime path of โ€œ/usr/local/lib/libdronecore_mission.soโ€ to โ€œโ€
โ€“ Installing: /usr/local/lib/arm-linux-gnueabihf/libjson11.a
โ€“ Installing: /usr/local/include/arm-linux-gnueabihf/json11.hpp
โ€“ Installing: /usr/local/lib/arm-linux-gnueabihf/pkgconfig/json11.pc
โ€“ Installing: /usr/local/include/dronecore/offboard.h
โ€“ Installing: /usr/local/lib/libdronecore_offboard.so
โ€“ Set runtime path of โ€œ/usr/local/lib/libdronecore_offboard.soโ€ to โ€œโ€
โ€“ Installing: /usr/local/include/dronecore/telemetry.h
โ€“ Installing: /usr/local/lib/libdronecore_telemetry.so
โ€“ Set runtime path of โ€œ/usr/local/lib/libdronecore_telemetry.soโ€ to โ€œโ€
โ€“ Installing: /usr/local/include/dronecore/logging.h
โ€“ Installing: /usr/local/lib/libdronecore_logging.so
โ€“ Set runtime path of โ€œ/usr/local/lib/libdronecore_logging.soโ€ to โ€œโ€
โ€“ Installing: /usr/local/include/dronecore/info.h
โ€“ Installing: /usr/local/lib/libdronecore_info.so
โ€“ Set runtime path of โ€œ/usr/local/lib/libdronecore_info.soโ€ to โ€œโ€
โ€“ Installing: /usr/local/include/dronecore/follow_me.h
โ€“ Installing: /usr/local/lib/libdronecore_follow_me.so
โ€“ Set runtime path of โ€œ/usr/local/lib/libdronecore_follow_me.soโ€ to โ€œโ€
Thank you for your support, Xiao.
Iโ€™ll try.
Hey. Did that work?
I am having compilation issues. I followed the same steps as described by Xiao.
Right now I get undefined reference to drone code_sdk::DronecodeSDK error.
Can you please help me out.
This is quite an old thread. I would recommend to create a new thread and include your specific error message.
