I have a ublox new 6m GPS module, it seems to have VCC RX TX GND communication pins, which is basically a Uart serial port. i would like to know what are the pins in the corresponding pins on gps interface on the pixhawk?? I don’t know if it is the px4 will recognize the GPS module if i connect it to the TELELM 1.
Because my GPS module interface is a UART, so it will be possible to connect it to TELEM1,
However i didn’t know if the GPS connector layout does exist, and I tough it is property connector for 3dr GPS.
I will connect it to GPS normal layout and tell you the results.
