Dear all,
I have been trying for a while now to make the SITL to run with in offboard mode, but I am hitting a wall at the moment.
I get the simulator for the iris with mavros up and running, I can see the topics OK, etc. But when I try the arm script, it doesn’t do it… or at least not for more than a few secs. My setup is the following:
- Ubuntu 14.04
- Ros Indigo
- Gazebo 6 (and plugins)
- Firmware tag 1.4.4
I start the simulator as per the instrucctions in the page http://dev.px4.io/simulation-ros-interface.html
Which runs without problems and start gazebo correctly.
Then, in a separate console I do:
rosrun mavros mavsafety arm.
which also seems to run without issues, but the arming, as said, last for a very short period and I get the following output in the simulator terminal:
[ WARN] [1474369104.164757665, 128.400000000]: CMD: Unexpected command 400, result 0
[ INFO] [1474369104.169157462, 128.402000000]: FCU: [cmd] ARMED by arm/disarm component command
[ERROR] [1474369104.220744497, 128.456000000]: FCU: failsafe mode on
[ERROR] [1474369104.271934291, 128.508000000]: FCU: Already landed, not executing RTL
[ INFO] [1474369104.323090877, 128.560000000]: FCU: RTL: completed, landed
[ INFO] [1474369104.374278747, 128.612000000]: FCU: [blackbox] rootfs/fs/microsd/log/sess001
[ INFO] [1474369104.425449299, 128.662000000]: FCU: [blackbox] recording: log001.px4log
[ INFO] [1474369107.202231222, 131.430000000]: FCU: [cmd] DISARMED by auto disarm on land
[ERROR] [1474369107.253864723, 131.482000000]: FCU: failsafe mode off
[ INFO] [1474369108.236144712, 132.462000000]: FCU: [blackbox] stopped (0 drops)
I also tried running the offboard Ros example in the page http://dev.px4.io/ros-mavros-offboard.html and it seems to be stuck trying to set the mode to offboard which never happens.
*** UPDATE 21.09.2016 ***
I have kept investigating and found the following things:
- If I change the rc files in the Tools gazebo to set the COM_DISARM_LAND to zero:
grep -r “COM_DISARM_LAND” *
posix-configs/SITL/init/rcS_gazebo_iris:param set COM_DISARM_LAND 3
posix-configs/SITL/init/rcS_gazebo_iris_opt_flow:param set COM_DISARM_LAND 3
posix-configs/SITL/init/rcS_gazebo_solo:param set COM_DISARM_LAND 3
posix-configs/SITL/init/rcS_gazebo_standard_vtol:param set COM_DISARM_LAND 5
posix-configs/SITL/init/rcS_gazebo_typhoon_h480:param set COM_DISARM_LAND 3
posix-configs/SITL/init/rcS_jmavsim_iris:param set COM_DISARM_LAND 3
posix-configs/SITL/init/rcS_lpe_gazebo_iris:param set COM_DISARM_LAND 3
posix-configs/SITL/init/rcS_lpe_gazebo_iris_opt_flow:param set COM_DISARM_LAND 3
posix-configs/SITL/init/rcS_lpe_jmavsim_iris:param set COM_DISARM_LAND 3
Then I don’t have the problem that disarming happens automatically anymore.
- Still, the firmware does not allow me to switch to offboard mode when in the RTL state NONE. So, what I did is run the following command:
rosrun mavros mavcmd takeoffcurr x x x x
This helps with the initial state not set to NONE
- However, I still can’t set the mode to OFFBOARD either programmically with the service call or with the script mavsys. I had to use this command that I saw in google:
rosrun mavros mavsetp x x x x
SUMMARY: Therefore I have a sequence of several commands that I have to perform in order to get the SITL armed in offboard mode, but it works. The sequence is now:
- change the files as above explaned
- build the firmware for gazebo
- rosrun mavros mavcmd takeoffcurr x x x x
- rosrun mavros mavsafety arm
- rosrun mavros mavsetp x x x x
So the questions I have:
- is there a better, less twisted way to get the SITL armed and offboard mode?
- what I am doing wrong that I can’t set the offboard mode programtically?
*** END UPDATE ***
Anyhelp would be highly appreciated.
Thanks,
Dr. Pablo Ghiglino
