Hi!
Im connecting my pixhawk 2.1 cube to my flir vue pro via mavlink over the serial2 port to geotag the pictures. The Flir has a RX and TX port, so I use that to connect to the Pix.
Using both cables, the geotag works just fine, buy I need to use just one cable, the TX from the pix to the RX from the flir. If I connect just that cable, it seems to be the serial port on Pixhwak doesnt starts, so the Flir cant geotag the pictures.
So, there is any way I can just use the TX from a serial port without connect the RX? thanks!
