Hello, ,
I just climbed my drone with a PIX4 flight controller. But I have a problem with the engines not running them. I changed ESC , the engines still don’t work .
I’ve calibrated ESC , flash ESC but it still doesn’t work
Cdt,
Hello, ,
Cdt,
Hi there,
This is a bit hard to debug with just this information but I have a couple of questions for you:
Are you able to arm? What mode are you in when you do the test? Can you try in stabilized mode?
If you can arm, could you share a logfile on logs.px4.io?
And for us to understand your wiring and find potential errors can you take some pictures of your setup and share it? Or describe in detail how the wiring is.
(And for next time: please don’t double post, I’ve deleted the other post.)
