Hello guys,
I wrote a new driver for an external IMU and I am publishing over uORB the accel, gyro, magnetometer and baro readings. I noticed in QGroundControl that the changes in yaw, pitch, roll are happening very very slowly. Unsafe to fly.
I plotted the attached graph for readings of magnetometer and the output of EKF2 quaternions (from log_...vehicleattitude_0.csv) when I moved the IMU on the table so that only the yaw change. As you can see, the delay between driver output and estimated quaternions take a very long time.
Platform: PX4v5 with IMU read over serial. uOrb messages posted at 200 Hz for all components (accel, gyro, mag and baro).
Questions: Any idea what can be the root cause of this and how can it be fixed ?
Any hints about where to look for the problem and how to find a solution will be highly appreciated.
Thank you,
MTM
