Dronecode Weekly Call: December 11, 2018
Tuesdays 5:30 PM CET, 11:30 AM EST, 8:30 AM PST (subscribe to calendar)
Join the call: https://zoom.us/j/229568741
Meeting ID: 229 568 741
Dial(for higher quality, dial a number based on your current location):
  • Switzerland: +41 (0) 31 528 0988
  • US: +1 646 876 9923 or +1 669 900 6833 or +1 408 740 3766
  • Germany: +49 (0) 30 3080 6188
  • Mexico: +52 554 161 4288
  • Australia: +61 (0) 2 8015 2088
  • United Kingdom: +44 (0) 20 3695 0088
  • South Korea: +82 (0) 2 6022 2322
  • Spain: +34 91 198 0188
  • Israel: +972 (0) 3 978 6688
  • Brazil: +55 21 3958 7888 or +55 11 4680 6788
  • International numbers available
Agenda:
  • 30min update from projects and working group leads
  • General Q&A
Meeting notes below
Updates from Project
Every project answers the following questions in 5min max:
  • What did you work last week?
  • What are you working on this week?
Dronecode SDK
Update by @JonasVautherin
  • Python generation, good progress, autogenerating the function arguments, and we have an example and run a mission from the python asyncio auto-generated code, almost ready to go
  • We had a contribution in the Makefile
  • offboard pull request that will be merged soon.
  • beginner label on Github is leading to contributions
Avoidance
Update by @thomasgubler
  • Improvements in stabilizing the architecture and code, unit tests, making codebase more robust
  • Making the avoidance be able to fly faster using only 1 camera
  • Pushing the speed limits we have currently, by a combination of working in the algorithm, plus config of sensors
Question: should we start testing regularly?
  • Action: Let’s bring testing up to team.
Flight Testing
Update by @Tony3dr
  • Weekly report
  • 31 flights, we had a couple of days of heavy rain
  • 2 prs tests
  • nuttx build
  • Action: when you mark something as not working that’s refering at your pixhawk mini, can we refrain this as an overall state of the board
QGC
Update by @rroche
  • No update this week.
PX4
Update by @dagar
  • Hardware test rack is coming up
  • @david_s5 working in getting us in sync with NuttX
    • Compressed ROMFS, helps with flash size.
    • Will probably be part of v1.9 but not for at release
  • Upstream NuttX build system to cmake
  • New Contributor: someone helped with snapdragon builds, let’s get the test team flying again.
    • Action: flight test snapdragon, do it on master for now.
    • Action: get Jenkins to build snapdragon binaries
MAVLink
Messaging
  • Basically investigating a bug with the latest update of ROS2 the messaging ros com stopped working, there is a work around for people already using this, but we are looking for the breaking change, enganged with eprosima
  • Plan is still to tie various loose ends before working with the avoidance team, making a new example with avoidance and messaging architecture,
  • Very well planned with issues.
  • Action: check with @TSC21 on dev call.
No Questions or Feedback.
Meeting recording
