Hi guys, I am wondering if the Pixracer support Dshot600, Oneshot42 or OneShot125?
I do not know much about esc motor protocol so I have been watching some videos on the youtube as you can see on links below and I also google the question Pixracer support Dshot but I did not find a clear answer so I was wondering if you guys can help me to clarify this question. It seems it support Oneshot but I am not sure how to test.
I did run some commands (PWM) through the Mavlink Console on the QGroundControl and I got some response on the motors but they did not work properly. I realised that I may be using the wrong command (PWM) so I though that may exist some sort of Dshot or Oneshot command but I donβt know.
I also found this note below on the documentation but I am not sure how to test
Note that in OneShot mode, the PWM range [1000, 2000] is automatically mapped to [125, 250
ESC MOTOR PROTOCOLS - PART 1
ESC MOTOR PROTOCOLS - PART 2
Hardware:
Radio Turnigy TGY-i6S
Speed controller Racerstar RS20Ax4 V2
Lipo Baterry Multistar 4S 5200mAh - AU $31.17
4x Emax MT2213-935KV 2212 Brushless Motor
3DR Radio Telemetry Kit
Pixracer 1.4
Thanks in advance guys and regards.
