I want to use mavros and gazebo SITL for simulation.
I followed instructions from two sources:
http://dev.px4.io/simulation-ros-interface.html and http://dev.px4.io/ros-mavros-offboard.html.
But errors occured.
First, I run the gazebo_sitl.
cd Firmware_clone
make posix_sitl_default
source ~/catkin_ws/devel/setup.bash
source Tools/setup_gazebo.bash $(pwd) build_posix_sitl_default
export ROS_PACKAGE_PATH=$ROS_PACKAGE_PATH:$(pwd)
export ROS_PACKAGE_PATH=$ROS_PACKAGE_PATH:$(pwd)/Tools/sitl_gazebo
roslaunch px4 mavros_posix_sitl.launch
Output is:
started roslaunch server http://ubuntu:46399/
SUMMARY
CLEAR PARAMETERS
* /mavros/
PARAMETERS
* /mavros/cmd/use_comp_id_system_control: False
* /mavros/conn/heartbeat_rate: 1.0
* /mavros/conn/system_time_rate: 1.0
* /mavros/conn/timeout: 10.0
* /mavros/conn/timesync_rate: 10.0
* /mavros/distance_sensor/hrlv_ez4_pub/field_of_view: 0.0
* /mavros/distance_sensor/hrlv_ez4_pub/frame_id: hrlv_ez4_sonar
* /mavros/distance_sensor/hrlv_ez4_pub/id: 0
* /mavros/distance_sensor/hrlv_ez4_pub/orientation: ROLL_180
* /mavros/distance_sensor/hrlv_ez4_pub/send_tf: True
* /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/x: 0.0
* /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/y: 0.0
* /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/z: -0.1
* /mavros/distance_sensor/laser_1_sub/id: 3
* /mavros/distance_sensor/laser_1_sub/orientation: ROLL_180
* /mavros/distance_sensor/laser_1_sub/subscriber: True
* /mavros/distance_sensor/lidarlite_pub/field_of_view: 0.0
* /mavros/distance_sensor/lidarlite_pub/frame_id: lidarlite_laser
* /mavros/distance_sensor/lidarlite_pub/id: 1
* /mavros/distance_sensor/lidarlite_pub/orientation: ROLL_180
* /mavros/distance_sensor/lidarlite_pub/send_tf: True
* /mavros/distance_sensor/lidarlite_pub/sensor_position/x: 0.0
* /mavros/distance_sensor/lidarlite_pub/sensor_position/y: 0.0
* /mavros/distance_sensor/lidarlite_pub/sensor_position/z: -0.1
* /mavros/distance_sensor/sonar_1_sub/id: 2
* /mavros/distance_sensor/sonar_1_sub/orientation: ROLL_180
* /mavros/distance_sensor/sonar_1_sub/subscriber: True
* /mavros/fcu_url: udp://:14540@loca...
* /mavros/gcs_url:
* /mavros/global_position/frame_id: fcu
* /mavros/global_position/rot_covariance: 99999.0
* /mavros/global_position/tf/child_frame_id: fcu_utm
* /mavros/global_position/tf/frame_id: local_origin
* /mavros/global_position/tf/send: False
* /mavros/image/frame_id: px4flow
* /mavros/imu/angular_velocity_stdev: 0.000349065850399
* /mavros/imu/frame_id: fcu
* /mavros/imu/linear_acceleration_stdev: 0.0003
* /mavros/imu/magnetic_stdev: 0.0
* /mavros/imu/orientation_stdev: 1.0
* /mavros/local_position/frame_id: fcu
* /mavros/local_position/tf/child_frame_id: fcu
* /mavros/local_position/tf/frame_id: local_origin
* /mavros/local_position/tf/send: False
* /mavros/local_position/tf/send_fcu: False
* /mavros/mission/pull_after_gcs: True
* /mavros/mocap/use_pose: True
* /mavros/mocap/use_tf: False
* /mavros/plugin_blacklist: ['safety_area', '...
* /mavros/plugin_whitelist: []
* /mavros/px4flow/frame_id: px4flow
* /mavros/px4flow/ranger_fov: 0.0
* /mavros/px4flow/ranger_max_range: 5.0
* /mavros/px4flow/ranger_min_range: 0.3
* /mavros/safety_area/p1/x: 1.0
* /mavros/safety_area/p1/y: 1.0
* /mavros/safety_area/p1/z: 1.0
* /mavros/safety_area/p2/x: -1.0
* /mavros/safety_area/p2/y: -1.0
* /mavros/safety_area/p2/z: -1.0
* /mavros/setpoint_accel/send_force: False
* /mavros/setpoint_attitude/reverse_throttle: False
* /mavros/setpoint_attitude/tf/child_frame_id: attitude
* /mavros/setpoint_attitude/tf/frame_id: local_origin
* /mavros/setpoint_attitude/tf/listen: False
* /mavros/setpoint_attitude/tf/rate_limit: 10.0
* /mavros/setpoint_position/tf/child_frame_id: setpoint
* /mavros/setpoint_position/tf/frame_id: local_origin
* /mavros/setpoint_position/tf/listen: False
* /mavros/setpoint_position/tf/rate_limit: 50.0
* /mavros/startup_px4_usb_quirk: True
* /mavros/sys/disable_diag: False
* /mavros/sys/min_voltage: 10.0
* /mavros/target_component_id: 1
* /mavros/target_system_id: 1
* /mavros/tdr_radio/low_rssi: 40
* /mavros/time/time_ref_source: fcu
* /mavros/time/timesync_avg_alpha: 0.6
* /mavros/vibration/frame_id: vibration
* /mavros/vision_pose/tf/child_frame_id: vision
* /mavros/vision_pose/tf/frame_id: local_origin
* /mavros/vision_pose/tf/listen: False
* /mavros/vision_pose/tf/rate_limit: 10.0
* /mavros/vision_speed/listen_twist: False
* /rosdistro: indigo
* /rosversion: 1.11.20
* /use_sim_time: True
NODES
gazebo (gazebo_ros/gzserver)
gazebo_gui (gazebo_ros/gzclient)
mavros (mavros/mavros_node)
sitl (px4/px4)
vehicle_spawn_ubuntu_7552_4607384523363716699 (gazebo_ros/spawn_model)
auto-starting new master
process[master]: started with pid [7564]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to 8a8c16f0-b0b7-11e6-9853-000c29399553
process[rosout-1]: started with pid [7577]
node name: sitl
data path: /home/zyq/px4/src/Firmware
commands file: /home/zyq/px4/src/Firmware/posix-configs/SITL/init/lpe/iris
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
0 WARNING: setRealtimeSched failed (not run as root?)
process[sitl-2]: started with pid [7602]
process[gazebo-3]: started with pid [7610]
process[gazebo_gui-4]: started with pid [7614]
process[vehicle_spawn_ubuntu_7552_4607384523363716699-5]: started with pid [7620]
INFO [dataman] Unkown restart, data manager file 'rootfs/fs/microsd/dataman' size is 47640 bytes
process[mavros-6]: started with pid [7621]
[ INFO] [1479821304.393029772]: FCU URL: udp://:14540@localhost:14557
[ INFO] [1479821304.393343712]: udp0: Bind address: 0.0.0.0:14540
[ INFO] [1479821304.393436053]: udp0: Remote address: 127.0.0.1:14557
[ INFO] [1479821304.393608685]: GCS bridge disabled
[ INFO [platforms__posix__drivers__ledsim] LED::init
[ INFO [simulator] Waiting for initial data on UDP port 14560. Please start the flight simulator to proceed..
[ INFO] [1479821304.555421828]: Plugin 3dr_radio loaded and initialized
[ INFO] [1479821304.559220350]: Plugin actuator_control loaded and initialized
[ INFO] [1479821304.560254603]: Plugin altitude loaded and initialized
[ INFO] [1479821304.812227139]: Plugin cam_imu_sync loaded and initialized
[ INFO] [1479821304.817701056]: Plugin command loaded and initialized
[ INFO] [1479821304.820659219]: Plugin distance_sensor blacklisted
spawn_model script started
[ INFO] [1479821304.836865293]: Plugin ftp loaded and initialized
[ INFO] [1479821304.865121876]: Plugin global_position loaded and initialized
[ INFO] [1479821304.865929889]: Plugin hil_controls loaded and initialized
[ INFO] [1479821304.865980532]: Plugin image_pub blacklisted
[ INFO] [1479821304.883901255]: Plugin imu_pub loaded and initialized
[ INFO] [1479821304.907276938]: Plugin local_position loaded and initialized
[ INFO] [1479821304.909247006]: Plugin manual_control loaded and initialized
[ INFO] [1479821304.932163120]: Plugin mocap_pose_estimate loaded and initialized
[ INFO] [1479821304.936041425]: Plugin param loaded and initialized
[ INFO] [1479821304.959535264]: Plugin px4flow loaded and initialized
[ INFO] [1479821304.972318570]: Plugin rc_io loaded and initialized
[ INFO] [1479821304.972434868]: Plugin safety_area blacklisted
[ INFO] [1479821304.992986404]: Plugin setpoint_accel loaded and initialized
[ INFO] [1479821305.048057451]: Plugin setpoint_attitude loaded and initialized
[ INFO] [1479821305.079119772]: Plugin setpoint_position loaded and initialized
[ INFO] [1479821305.122359729]: Plugin setpoint_raw loaded and initialized
[ INFO] [1479821305.132584656]: Plugin setpoint_velocity loaded and initialized
[ INFO] [1479821305.171421701]: Plugin sys_status loaded and initialized
[INFO] [WallTime: 1479821305.179778] [0.000000] Loading model xml from file
[INFO] [WallTime: 1479821305.180019] [0.000000] Waiting for service /gazebo/spawn_sdf_model
[ INFO] [1479821305.194367707]: Plugin sys_time loaded and initialized
[ INFO] [1479821305.199679132]: Plugin vfr_hud loaded and initialized
[ INFO] [1479821305.199769050]: Plugin vibration blacklisted
[ INFO] [1479821305.248354842]: Plugin vision_pose_estimate loaded and initialized
[ INFO] [1479821305.261666685]: Plugin vision_speed_estimate loaded and initialized
[ INFO] [1479821305.272122837]: Plugin waypoint loaded and initialized
[ INFO] [1479821305.272229519]: Autostarting mavlink via USB on PX4
[ INFO] [1479821305.272358516]: Built-in SIMD instructions: SSE, SSE2
[ INFO] [1479821305.272402982]: Built-in MAVLink package version: 2016.5.20
[ INFO] [1479821305.272437647]: Built-in MAVLink dialect: ardupilotmega
[ INFO] [1479821305.272470903]: MAVROS started. MY ID 1.240, TARGET ID 1.1
[ INFO] [1479821305.543772214]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1479821305.545882892]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[ INFO] [1479821306.019725360, 0.022000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1479821306.078201046, 0.056000000]: Physics dynamic reconfigure ready.
[INFO] [WallTime: 1479821306.091521] [0.066000] Calling service /gazebo/spawn_sdf_model
[INFO] [WallTime: 1479821306.207724] [0.132000] Spawn status: SpawnModel: Successfully spawned model
[vehicle_spawn_ubuntu_7552_4607384523363716699-5] process has finished cleanly
log file: /home/zyq/.ros/log/8a8c16f0-b0b7-11e6-9853-000c29399553/vehicle_spawn_ubuntu_7552_4607384523363716699-5*.log
Then I run the offb_node node in another terminal, this teminal outputed nothing.
But the SITL teminal began to give error messages:
[ERROR] [1479812333.873957573, 240.232000000]: MODE: Unsupported FCU
[ERROR] [1479812338.925361421, 245.282000000]: MODE: Unsupported FCU
And the rqt graph showed:
The mavros node had no connection with the gazebo node.
I run rostopic echo /diagnostics, the teminal outputed as follow. It showed FCU connection:message:not connected.
header:
seq: 150
stamp:
secs: 145
nsecs: 0
frame_id: ‘’
status:
level: 1
name: mavros: FCU connection
message: not connected
hardware_id: udp://:14540@127.0.0.1:14557
values:
key: Received packets:
value: 0
key: Dropped packets:
value: 0
key: Buffer overruns:
value: 0
key: Parse errors:
value: 0
key: Rx sequence number:
value: 0
key: Tx sequence number:
value: 86
key: Rx total bytes:
value: 0
key: Tx total bytes:
value: 220368
key: Rx speed:
value: 0.000000
key: Tx speed:
value: 6377.000000
level: 2
message: No satellites
values:
key: Satellites visible
value: 0
key: Fix type
value: 0
key: EPH (m)
value: Unknown
key: EPV (m)
value: Unknown
level: 2
name: mavros: Heartbeat
message: No events recorded.
values:
key: Heartbeats since startup
value: 0
key: Frequency (Hz)
value: 0.000000
key: Vehicle type
value: Generic
key: Autopilot type
value: Generic
key: Mode
value: ‘’
key: System status
value: Uninit
level: 0
message: Normal
values:
key: Sensor present
value: 0x00000000
key: Sensor enabled
value: 0x00000000
key: Sensor helth
value: 0x00000000
key: CPU Load (%)
value: 0.0
key: Drop rate (%)
value: 0.0
key: Errors comm
value: 0
key: Errors count #1
value: 0
key: Errors count #2
value: 0
key: Errors count #3
value: 0
key: Errors count #4
value: 0
level: 2
message: No data
values:
key: Voltage
value: -1.00
key: Current
value: 0.0
key: Remaining
value: 0.0
level: 2
name: mavros: Time Sync
values:
key: Timesyncs since startup
value: 0
key: Frequency (Hz)
value: 0.000000
key: Last dt (ms)
value: 0.000000
key: Mean dt (ms)
value: 0.000000
key: Last system time (s)
value: 0.000000000
key: Time offset (s)
value: 0.000000000
I want to know how to solve this problem.
And whethe I can do onboard operations with gazebo sitl?
If you have good gazebo simulation instructions, could you recommend to me?
Could you help me? Thanks.
