Detected 0 radio channels
Hello everyone,
It’s been several days since I’m stuck on this problem and I can not find a solution.
When I plug my pixhawk into Q Ground Control, I can not calibrate the radio.
The receiver is binder and functional (test on another pixhawk). And I receive an error message: “Detected 0 radio channels”
Where can the problem come from?
Etienne
Did not you have found the answer?
The receiver works on another pixhawk, but not this one. So there seems to be some faults with your Pixhawk.
no, I still have not solved the problem.
And I try to reset it to the factory settings but it does not change anything.
