I just uploaded PX4 firmware into Crazyflie 2.0 and everything is working really good!
I was able to make a simple application that print data from accelerometer, gyro and magnetometer sensors (utilizing sensor_combined.msg
topic) and also that turn on the actuators (utilizing drv_pwm_output.h
driver) with a given PWM signal.
However, I’m not beeing able to request data from optical flow and range sensors (from the Flow deck). I’ve tried the distance_sensor.msg
and optical_flow.msg
topics but both with no success.
Did anybody had a similar problem?
Thank you!
