Hi @Thomas.leitgeb & @Sejin_J , I'm trying to do a similar project also. The only difference with mine is that unlike the convergence my airframe is of a standard plane configuration, with aileron, elevator and rudder control. But it still has three motors, in a similar configuration to the convergence, with the rear being fixed and the front wing mounted rotors both tilt.
I was wondering if you knew which model is best to start with, would it be ok to start with convergence and change parameters or is there a better suited approach for this?
Thanks in advance
