Hi.
I would like some help on how to get connection between the QGC and my pixhawk mini via a dx9 tx (with dragonlink v3). What are the Mavlink settings etc or setups required? I have not been successful after following instructions.
Any help would be appreciated as im sure more people are using this setup and without successful connection, I wont be able to “arm” the system to work the servos and motor and fly on my flying wing.
Thanks.
I assume its telemetry via Dragonlink your thinking of.
You have to sett the telemetryport you are using with Dragonlink data to “companion computer.”
Then you use the settings mentioned on the Dragonlik website
It worked for me. Streaming telemetry via dragonlink and via bluethoth to my phone
Hi Ullteppet,
Thank you for the response.
Which software did you use? QGC or Mission Planner?
Many Thanks
Hello, same here try to use dragonlink telemetry with PX4 qgroundcontrol with no results as some of the commands are not available on parameters
Anyone is using Qgroundcontrol and dragonlink telemetry?
using qgc with a holybro pixhawk4.
Follow the wiering guide at dragonlinkrc.com
and the settings for the dragonlink equipment, com, baudrates etc…
the pix has two telemetry ports. port one i’m using to stream telemetry to the osd.
the second telemetryport i use to stream mawlink data via dragonlink rc link andt trough bluethoot to my tablet.
in the parameterlist i found telemetry port 2 and set it to companion computer… and voila… it works.
