Changing motor direction
I know that motor direction can be changed by swapping any two wires on a motor but can motor direction be changed through Q ground control, and if so how? tia
The direction of the motor is controlled through the ESC and qgroundcontrol has no control over this. The flight controller only tells the ESC at what rate the motor should spin.
