Hi, i´m tired to work with df13 connectors. I´m thinking on try to change, for example; gps2, usb, telem1 and telem2 inputs, to a usb port. I´m new on the uav world, can someone more experimented share your opinion about it with me?
Telemetry can work without RTS CTS so you only hace to use 4 pins, not?
And, in case you want to use the six pins, why the df13? why not a mini din for example?
Please, show me the errors i´m probably making
Thanks
yep, but groung module use usb, so you can use a ground module like air module not? Anyway, it´s not the first time i have to conect the air module to the usb computer and i could configure it perfectly
JST GH 6P SMT 1 piece $0.59
JST GH 6P Housing 1 piece $0.17
JST GH Pin 1 piece $0.11~$0.35
If you have to have a LOCKING connector this appears to be a good fit. I have been using Molex PicoBlade and they work well other than the removal and insertion force required but once they are seated they are good.
I do like the socket, it has metal on two sides that make the GH part have more contact area compared to DF13 or PicoBlade.
