Bumping. Definitely having this issue as well with:
- QGroundControl version 3.2.2 & Daily Build 2017-08-15
- Windows 10 (Anniversary Update)
- PX4 Flight Stack stable release version 1.6.5
- 3DR Pixhawk 1 board
- Futaba R8014HS RC Receiver
- Futaba T10CAG 2.4GHz RC Trasmitter
Anyone have any idea what's happening with the HIL mode? I checked using QGroundControl's Mavlink Inspector and found the HIL_ACTUATORS_CONTROLS had all channel values to 0 except for the Kill Switch (which I set up to Channel 8), RTL Failsafe Switch (set to channel 5) and for changing flight modes (set up to channel 7--a dial). Attached is my attempt at flipping the Kill Switch and controlling the plane,
which Mavlink detected that only the Kill Switch value changed (0.5 to 0).
Since I'm using Windows, I can't really make a custom firmware with the guide available on dev.px4.io (the windows_bash_nuttx.sh immediately failed to replace any Linux command since it's using sudo itself). Any help would be appreciated.
