I have followed the steps as mentioned here: https://dev.px4.io/en/setup/dev_env_linux_ubuntu.html
I get this output:
root@px4test-ubuntu:/home/oaasadmin/src/Firmware# arm-none-eabi-gcc --version
arm-none-eabi-gcc (GNU Tools for ARM Embedded Processors) 5.4.1 20160609 (release) [ARM/embedded-5-branch revision 237715]
Copyright © 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
I got the source and trying to build px4 firmware using the cmd: make px4fmu-v2_default
failed with the following error:
Scanning dependencies of target nuttx_patch_px4io-v2
[ 13%] Built target px4fmu-v2-nuttx_patch_00028-BACKPORT-mtd-FLASH-corruption.patch
[ 13%] Built target nuttx_patch_px4io-v2
Scanning dependencies of target px4fmu-v2-nuttx_patch_00029-BACKPORT-stm32-serial-upstream-sans-IRQ.patch
[ 14%] px4fmu-v2: nuttx-patches/00029-BACKPORT-stm32-serial-upstream-sans-IRQ.patch applied
Scanning dependencies of target nuttx_configure_px4io-v2
[ 15%] Configuring NuttX for px4io-v2 with nsh
[ 15%] Built target px4fmu-v2-nuttx_patch_00029-BACKPORT-stm32-serial-upstream-sans-IRQ.patch
Scanning dependencies of target px4fmu-v2-nuttx_patch_00030-BACKPORT-fix-arm-none-eabi-gcc-7-warnings-nuttx.patch
[ 15%] px4fmu-v2: nuttx-patches/00030-BACKPORT-fix-arm-none-eabi-gcc-7-warnings-nuttx.patch applied
[ 15%] Built target px4fmu-v2-nuttx_patch_00030-BACKPORT-fix-arm-none-eabi-gcc-7-warnings-nuttx.patch
[ 15%] Built target nuttx_configure_px4io-v2
Scanning dependencies of target px4fmu-v2-nuttx_patch_00031-BACKPORT-fix-arm-none-eabi-gcc-7-warnings-apps.patch
Scanning dependencies of target nuttx_export_px4io-v2
[ 15%] px4fmu-v2: nuttx-patches/00031-BACKPORT-fix-arm-none-eabi-gcc-7-warnings-apps.patch applied
[ 15%] Building NuttX for px4io-v2 with nsh
make[4]: warning: jobserver unavailable: using -j1. Add ‘+’ to parent make rule.
[ 15%] Built target px4fmu-v2-nuttx_patch_00031-BACKPORT-fix-arm-none-eabi-gcc-7-warnings-apps.patch
make[5]: gcc: Command not found
make[5]: *** [mkconfig] Error 127
make[4]: *** [tools/mkconfig] Error 2
src/modules/px4iofirmware/CMakeFiles/nuttx_export_px4io-v2.dir/build.make:60: recipe for target ‘px4io-v2/nuttx_export.stamp’ failed
make[3]: *** [px4io-v2/nuttx_export.stamp] Error 2
CMakeFiles/Makefile2:8590: recipe for target ‘src/modules/px4iofirmware/CMakeFiles/nuttx_export_px4io-v2.dir/all’ failed
make[2]: *** [src/modules/px4iofirmware/CMakeFiles/nuttx_export_px4io-v2.dir/all] Error 2
make[2]: *** Waiting for unfinished jobs…
Scanning dependencies of target px4fmu-v2-nuttx_patch_00032-BACKPORT-stm32f7-pinmap-FMC-I2C4-fixes.patch
[ 15%] px4fmu-v2: nuttx-patches/00032-BACKPORT-stm32f7-pinmap-FMC-I2C4-fixes.patch applied
[ 15%] Built target px4fmu-v2-nuttx_patch_00032-BACKPORT-stm32f7-pinmap-FMC-I2C4-fixes.patch
Makefile:160: recipe for target ‘all’ failed
make[1]: *** [all] Error 2
Makefile:165: recipe for target ‘px4fmu-v2_default’ failed
make: *** [px4fmu-v2_default] Error 2
As you can see, arm-gcc is available in the system but getting gcc not found. Can you please help me here?
