Iām in the middle of a build so havenāt tested yet, but it looks like the pwm output is set at 400hz. Is that for all outputs, or can I set 50hz for AUX outputs?
What FC you are using?
default AUX outputs should be 50Hz.
Better to use 50Hz for servos as most of them are designed to accept signal of that frequency.
Ok, cool. I didnāt know that the AUX were different output rate. Iām using a Pixhawk 1 (2.4.6). I havenāt powered it up yet, but looking at the config file had me worried that it would all be 400hz. Iām still learning about mixers and outputs, etc. Thanks for the response.
