Hi, I am new to px4 and I am trying to follow the dev guide and build the firmware.
I managed to clone the upstream repository, however I am getting an error when executing the make command:
make px4fmu-v2_default
The error I receive:
$ make px4fmu-v2_default
/bin/sh: cmake: command not found
rm: cannot remove directory `/usr/home/Julian/src/Firmware/build_px4fmu-v2_default’: Permission denied
make: *** [px4fmu-v2_default] Error 1
I tried to run the PX4 as admin since it seems to be a problem with permission, but I still got the same error. I would appreciate any help, thank you
You should install cmake and configure environment variable.
After that you can execute “cmake --version” in DOS cmd or git bash.
If there is a cmake note,you can try to rebuild your code.
Were you able to fix this issue? I’m getting the same error.
I have installed cmake (I thought it came with the px4 toolkit, but I guess not?).
I am running the PX4 Console as an administrator.
I tried running “make clean” but also get an error: make[1]: *** No rule to make target ‘clean’. Stop.
I have disabled .NET Framework 3.5 (includes .NET 2.0 and 3.0) per recommendation on another thread
I am using Windows 10.
