Hello everyone,
I just received my new RC set. Radio calibration has done. Everything is ok, signals are sending to autopilot correctly for all channels - as far as I see on QGC monitor
I can ARM with QGC without a problem. I can arm with companion computer, over MAVRos as well.
However, autopilot doesn’t react at all when I tried to arm with the transmitter. No beep, no colour change on the led, no error on the QGC…
I’m using this quad with companion computer, so I have changed a few parameters for that.
SYS_COMPANION = 921600
MAV_COMP_ID = 50
COM_RC_IN_MODE = Joystick/No RC Checks
CBRK_USB_CHK = 197848
Rest of parameters are default values. I could not figure out where is the problem.
