Hello Folks,
I’m trying to achieve a passthrough mixer matrix on a multirotor UAV mounting a Pixhawk mini with PX4 firmware (v1.7.3).
I set-up the mixer as IO_pass because our custom flight controller should publish the actuators setpoint (pwm) normalized between -1 and +1 using the actuator_controls_0 topic in order to directly drive the actuators (we would like to by-pass the px4 mixer).
The problem is: when the system is disarmed, only the fourth channel (the “throttle” signal, or in our case the fourth motor) turns out to have the desired pwm value (specified with “pwm disarmed” command) while the other channels have the pwm value which would result as in armed state, instead of the disarmed value.
When the system is armed all the channels have the desired pwm values.
Additional info:
We are using as SYS_AUTOSTART 4001 (the canonical quadrotor) and we are overriding the quad_x mixer using the SD card defining a file called /etc/mixers/quad_x.main.mix and copy/pasted inside the IO_pass definition:
Passthrough mixer for PX4IO
This file defines passthrough mixers suitable for testing.
Channel group 0, channels 0-7 are passed directly through to the outputs.
M: 1
O: 10000 10000 0 -10000 10000
S: 0 0 10000 10000 0 -10000 10000
M: 1
S: 0 1 10000 10000 0 -10000 10000
M: 1
S: 0 2 10000 10000 0 -10000 10000
M: 1
S: 0 3 10000 10000 0 -10000 10000
M: 1
S: 0 4 10000 10000 0 -10000 10000
M: 1
S: 0 5 10000 10000 0 -10000 10000
M: 1
S: 0 6 10000 10000 0 -10000 10000
M: 1
S: 0 7 10000 10000 0 -10000 10000
We added also a /etc/config.txt:
set MAV_TYPE 0
param set MAV_TYPE ${MAV_TYPE}
set PWM_OUT 12345678
param set PWM_RATE 50
And a /etc/extras.txt file as follow:
pwm rate -r 400 -c 1234
pwm failsafe -p 1000 -c 1234
pwm disarmed -p 900 -c 1234
pwm min -p 1050 -c 1234
pwm max -p 1950 -c 1234
pwm failsafe -p 1489 -c 5678
pwm disarmed -p 1489 -c 5678
pwm min -p 828 -c 5678
pwm max -p 2150 -c 5678
Any ideas?
Have a nice day,
Mattia.
